coil over spring rate
Getting a stiffer rate spring may not be a great idea with those drag shocks, the car is going to ride worse, launch worse, and bounce more as a non-gas charged drag shock like strange won't be able to deal with the higher spring rate.
The shocks you have are not really geared toward being a street car shock, more of a Drag oriented shock, so changing be spring rate on the existing shocks you have will likely make it worse like JD is saying. You're narrowly basing the low stance of the car to the spring rate. fixing the issue you're having with the car being low is not going to have much to do with the spring rate. If you're happy with the way the car feels/drives and handles then change the spring perch location by adjusting it up further and raising the car up. If you're not happy with the way the car feels/drives and handles then you're best bet would be to change the spring rate and the shock to accommodate the spring rate you're wanting to run and if the car isn't geared toward drag racing, then the stange shocks are not what should be on a street car IMO.
