Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro and Firebird Aftermarket Performance Modifications<br>Overview of popular modifications to customize your Camaro or Firebird.
Best suspension upgrades for 4th gen ls
#41
Hi, looking to upgrade suspension on '02 Z28 convertible (PA roads) without lowering the car. Stiff ride is fine but looking for street performance. Thinking new shocks/struts, springs, bushings. I see Koni is recommended a lot in this thread. Is there a street kit you recommend for simplicity and compatibility? Or recommend buying components separate? Appreciate any guidance and let me know if easier to call your shop (and #). Thanks
#42
LS1TECH Sponsor
You don't need to go to Koni Sport if something is stopping you. However I would it would be my recommendation. And it is what is on pretty much all of my cars that don't have something either beyond those, or by rule for my autocrossing don't allow change.
Can't change springs, there are no aftermarket springs that are more performance oriented than what you have and also not lower. And if there was anything wrong with your springs your car would be sagging. Sounds like it is not sagging. So you're not going to do anything there. And sure we have all new bushings and ball joints and those things available, that's easy. There is no real kit here. By , that's easy. There is no real kit here. Decide on a set of shocks, again I would tell you in recommend sway bars strongly, not any version by the way many companies don't have a big enough front or they have two large rear or something like that. And then we can get you the bushings and the ball joints and the tie rod ends and all that stuff if you want to refresh all the stock arms.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
The following users liked this post:
Y2K_Frenzy (04-24-2024)
#43
Bilstein
#44
LS1TECH Sponsor
Here’s a decent review on Bilstein shocks.Bilstein
__________________
#45
Although not really relevant. The SLP version of the shock doesn't exist anymore. I have hd's in stock though and it's certainly not a terrible choice. You could do far worse. Keep in mind that Bilstein fronts are the shock only. There is no lower spring perch there is no spring indexing ring there are no dust boots there are no bump stops. Koni come with those, but those, but Bilstein fronts do not.
#46
LS1TECH Sponsor
Nope. And while at times they were similar they were not identical. Both front and rear valvings differed. Overtime some of that was incorporated into the regular production shocks but not all of it.
__________________
#47
*Edit*
I think the “kit” is discontinued and the vendor is just selling them individually now. The singles are listed as B6’s but they have the same description as their “out of stock” “Level II Kit.” “Bilstein designed these for SLP..” Too lazy to update the description I guess.
![](https://cimg5.ibsrv.net/gimg/ls1tech.com-vbulletin/1170x998/img_4666_ed34395449be7ec75ba009be4ec3169df63e77a7.jpeg)
#48
LS1TECH Sponsor
The shocks weren't any different between them anyway, that was the springs.
__________________
#49
![Thumbs down](https://ls1tech.com/forums/images/icons/icon13.gif)
Shocks are the single MOST IMPORTANT thing to make better on these cars. You can certainly run my springs on stock shocks, but considering that the stock shocks are pretty weak and are usually quite overwhelmed by the taller, softer stock springs, putting shorter and stiffer springs on usually isn't a prescription for the best driving car. I'd love to say my springs were so magical they could make any shock look good. But I'm not a big one for telling tall tales, and well others do that plenty (claim their springs "work with any shock"). Not my thing, rather be honest.
Y2K_Frenzy (05-12-2024)
#50
LS1TECH Sponsor
Check the attitude. Results don't lie. I've got them. What I don't have is patience for people who have no idea and want to continue to be ignorant. The Internet is chock full of experts in their own minds and I generally avoid trying to battle them, but every once in a while a Grade A jackass, like you shows up.
__________________
#51
I carry about everything, including the junk most others, presumably like you would "recommend" without any supporting results.
SteveC (05-13-2024)
#52
Y2K_Frenzy (05-13-2024)
