Looking for thoughts on rough ride
LT1 pro kit springs- thinking this is it
KYB adjustables all the way around
Subrframe connectors bolt in
double adjustable panhard bar
Founders On-Car Adjustable Lower Control Arms Poly/Rod
Founders On Car Adjustable Panhard Rod Bar Rod/Rod Style
Founders Lower Control Arms Relocation Brackets
BMR trans mount adj torque arm
Since dropping with the springs and now with LT headers and Texas speed Y I'm scraping often. So i'm looking to maybe go back to factory springs to help comfort if this seems to be culprit.
Don't get me wrong I love the drive but getting older and the fact that fiancé refuses to ride in it lol, need to make some changes. Besides heard these springs are bad for launch anyways.
Hook me up with some thoughts and thanks in advance.
your KYB's are not helping the cause, as they adjust compression with rebound on the same ****, so the higher you go the more compression you are dialing up, other single adjustable shocks are not like that.
And your rear LCA's are not helping either, go back to the stock ones and see if thats any better.
Keep tire pressure around 30psi ideally as well.
http://www.foundersperformance.com/1...ce-poly-joint/
LS1 Prokit has a softer spring rates.
The LS1 Prokit has a 400 lb.in. front and, 80-137 lb.in. rear spring rates.
The LT1 Prokit has a 366-600 lb.in front, and 94-160 lb.in. rear spring rates.
OP, Your problem (as far as lower control arms go) is the rod end, they aren't practical for a street car and are known to cause harsh/noisy rides.
