inside of front tires bald
It's scary to think that there are shops in business out there like that. Find a shop that knows what they're doing.
It sounds like they tried to make adjustments in the wrong order...The toe is adjusted last on these cars. It is possible to run out of toe adjustment if the camber bolts are moved all the way "in" ("in" being towards the engine). i doubt that's the case since having the camber bolts all the in would result in positive camber, causing a lean on the outside edge of the tire...which you don't have. Eventhough the tie rods aren't that deep the adjustment needed is of very fine granularity...by the 16th of an inch.
If you take a birds eye view of your car, think of a toe out as your front tires forming a "V" when looking from the rear. kinda creates a dragging effect on the inside of the tires...which is what is causing your wear.
