inside of front tires bald
I just realized you are in Ocala. It is a little bit of a drive, but we deal with Weaver's here in Seffner. He does all of our stuff so he knows his way around these cars and will get it dialed in for you. Also if you are in the area, feel free to stop by and I'll show you around the shop if you'd like
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Yep, this is exactly what I was looking for, and what I expected to see. What they have effectively done is narrow your track width by bringing the arms in. This is why the toe rods are run in so far and still not enough. Your camber and caster angles must be pretty crazy also. Definitely take it to a shop that has more knowledge of these cars. Look in my sig for a link to find a reputable shop near you.
Thanks
Got the alignment done today. Goes nice and straight down the road. He said he could tell by looking at it that it had been in a wreck before but still had no problem getting everything in spec. So much nicer to drive! I put a set if used tires on the front for now. Going to make sure they are wearing good then get a set of 18s
