passenger side lower than drivers heater hose mod
As stated my pass side sits lower. I did the heater hose mod and my rear pass sits about 1.5" above the tire right where I want it. The rear drivers side is about 2.5". Before the mod my drivers side Sat higher. The fronts are unaltered and the pass side is about 2.5" and drivers side is about 2.75" I planned on cutting the fronts about 3/4 of a coil to give me about an inch drop, but I can't figure out the rears? I'm considering cutting 1/2 to 3/4 of a coil and putting the isolators back in.
Rear
![](http://i59.tinypic.com/2lk64n5.jpg)
On an unrelated note, do you think these are torque creases? The pass side has a similar one or is that just a dent? I bought the car all it has is a flowmaster i recently put a lid on but haven't driven it.
Rear
![](http://i59.tinypic.com/nec75h.jpg)
Sounds like the right side spring is the culprit since it was sitting lower before the mod and now after. Since the rear springs are so easy to replace, I would swap the right to the left, and left to the right and see if the left side now sags.
if it is the spring do you think I could cut 1/4 coil off the taller spring to compensate?
I had this issue too the passenger side was sitting almost an inch lower in the back than the driver side. ive had the car for 5 years now. it was like that when i got it but not as bad as it was now so i switched them and put the passenger side one on the driver side and vice versa and it leveled out the car.
passenger side eventually sits lower over time because of the panhard bar and how it moves in an arc so when you are driving in a turn it must put more pressure on the passenger spring the the driver spring.
LS1Tech Premium Sponsor
This is a common issue on these cars. It is not a spring or control arm issue. No one seems to have been able to pinpoint the exact cause of it actually. I have seen people with stock and aftermarket springs, control arms, shocks etc have the same problem. To compensate, I have seen some heater hose mod only the driver's side and leave the isolator in the passenger side. Or, if you run a longer length of heater hose on the passenger spring so that it covers more of the end coils and doesn't allow them to compress completely together, and do the HH mod like normal on the driver's side it will level it out as well.
Any issue I might have doing that?
