Lowering my car, looking for opinions
I have a 2002 Camaro SS. Within the next few weeks, it will be getting new BMR springs and a set of Bilstiens on all four corners. Also, energy suspension front/rear sway bar bushings and links. My question...how necessary is an adjustable panhard bar or any other suspension components when doing this? I have the stock size wheels and tires and plan on keeping it that way. You can read so many things, from "You NEED it" to "Don't waste your money." I'm very picky when it comes to my rides. I don't want want things out of whack, vibrations, etc. A friend of mine that builds these cars, says I don't need it. Just would like some others with experience to chime in. Thanks!
you know, I thought the same thing but decided due to mileage and my upcoming lowering (shocks arrived yesterday) I decided to replace ALL the bushings in my suspension to that end I got all MOOG front bushings and ball joints and the Founders 3-piece poly rear control arms and on car adjustable pan-hard bar, so far I have only done the drivers side rear lower control arm and pan-hard bar (one of the lower control arm bushings was the wrong size so I can't install the other one till it arrives) and already I tell a HUGE difference in the rear of the car and the way I figure it, by the time I bought Moog bushings for the stock rear lower control arms and removed them, borrowed one of parents cars, went to a shop and paid them to press out the old and press in the new bushings I'm not that far from the cost of the Founders and I can do those myself rather easily and they look better to boot.
Also I would definitely get the on car adjustable pan-hard, just to be sure your able to center things up, it's not that much money after considering the 600-700 you just spent on shocks and springs.
also depending on mileage I would suggest replacing all the front control arm bushings and ball joints (mine have over 205k miles so it was a must to me).
LS1Tech Premium Sponsor
With the change in ride height it will alter the pinion angle of the car but it is hard to say if the change will be extreme enough to cause any kind of extra vibrations. We have found that it will on some cars and won't on others so it is kind of a toss up. Once you get your BMR lowering springs installed drive the car around and see if you have any kind of extra vibrations that are speed related, if you do I would recommend one of BMR adjustable full length torque arm (TA001) which will allow you to fine tune the pinion angle.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
I too agree that the on car adjustable pan-hard rod is the way to go. I've got the Founders piece as well. However I did not like the poly rear LCAs at all. The rear couldn't articulate like it should. There are a lot of folks that will tell you that the stock LCA is just fine. I did press in some Moog bushings in the stockers .... so they are somewhat upgraded.
^ Any and all poly bushings have binding issues. Also I hate on car adjustable phb's. I prefer single adjustable because once its set you're done unless you change the ride height.
On car adjustable phb's are way too prone to having the jam nuts come loose and coming out of adjustment.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
If there is anything we can help you out with let us know.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
