Phb & lca ?
Old Mar 17, 2014 | 01:13 AM
98z8uup's Avatar
Default Phb & lca ?
I was on Founders web site looking at the PHB & LCA, and I didn't know which one to get of each. The car is just a street car.
Old Mar 17, 2014 | 01:57 AM
99Bluz28's Avatar
Here's what I'd recommend:
http://www.foundersperformance.com/1...ce-poly-joint/
http://www.foundersperformance.com/s...rome-moly-end/
Old Mar 17, 2014 | 02:38 AM
Zlow28's Avatar
for a street car, id recommend to spend the extra money and go with BMR rubber on both ends.
Old Mar 17, 2014 | 08:23 AM
Dainius56's Avatar
the 3-pice poly LCA's linked above are amazing.... Just had them installed and they replaced a poly/rod combo that was real noisy...these are quiet and make for a firm ride. Highly recommend them
Old Mar 17, 2014 | 09:11 AM
98z8uup's Avatar
[QUOTE=99Bluz28;18088084]Here's what I'd recommend:
http://www.foundersperformance.com/s...rome-moly-end/[/QUO
Thanks for the help. I will look into these more.
Old Mar 17, 2014 | 09:14 AM
98z8uup's Avatar
Which one do you recommend from them?
Old Mar 17, 2014 | 09:24 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
If you aren't planning on running a crazy wheel/tire combination than our BMR non-adjustable lower control arms (TCA001) sound like a perfect option for you. Also for a little extra you can get rubber bushings in them rather than the poly-urethane bushings that normally are included. I attached a picture of what they would look like.
As far as the panhard bar goes, if you plan on lowering the car I would recommend using our BMR adjustable panhard bar (PHR002) of if you plan on staying at factory ride height you can use our BMR non-adjustable panhard bar (PHR001). I could also do rubber bushings in the panhard bar for a small additional charge.
If you are interested shoot me a PM or give me a call here at the shop (813)986-9302 and we can get you squared away.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Mar 17, 2014 | 10:04 AM
98z8uup's Avatar
Sorry everyone for not saying I will be lowering the car with BMR springs.
Old Mar 17, 2014 | 12:27 PM
z-maro's Avatar
I have heard that even going with double rod/heim/roto ends on the PHB, there is very little increase in NVH. Is there any truth to this, or do they create as much NVH as double rod LCA's are know for?
Old Mar 17, 2014 | 02:29 PM
99Bluz28's Avatar
True, I run a GW adjustable PHB with spherical bearing on one end and rod-end on the other, I've never experienced NVH except for one time when a jam nut came loose on the rod-end. I've had poly/poly, poly/rod-end, rod-end/rod-end, and my current phb listed above. As far as the life of spherical bearings and rod-end they'll last virtually forever(in PHB location) if they don't get rusty.
Old Mar 17, 2014 | 02:31 PM
99Bluz28's Avatar
Well, in that case you'll also want a set of LCA relocation brackets.
Old Mar 17, 2014 | 08:23 PM
JD_AMG's Avatar
What is "street car" for you?
Drag racing? Handling? Ride quality?
What are you looking to achieve?
Old Mar 17, 2014 | 08:27 PM
wavebyby's Avatar
I have the founders on car adjustable pan hard bar and on car adjustable lower control arms with the three piece rubber ends also picked up there relocation brackets . I love their products and most of all their prices !!!
Old Mar 17, 2014 | 08:29 PM
wavebyby's Avatar
Also when you lower the car you will need the adjustable phb so you can recenter the rear end definitely get the on car adjustable one !!
Old Mar 18, 2014 | 02:20 AM
98z8uup's Avatar
I am looking for ride quality. Handling would be great to.
Old Mar 18, 2014 | 02:39 AM
98z8uup's Avatar
That's the thing, they have 3 0f them that says on the car adjustable.
Which one to get?
Old Mar 18, 2014 | 07:12 AM
wavebyby's Avatar
Which one to get?
I got this one with the poly / poly ends
http://www.foundersperformance.com/p...-Bushings.html
Old Mar 18, 2014 | 07:14 AM
wavebyby's Avatar
ive had the ones with the rod ends and i hated the noise they made
Old Mar 18, 2014 | 09:01 AM
98z8uup's Avatar
I will be putting my order in today.Thanks
Old Mar 18, 2014 | 09:28 AM
SnakeEaterSS's Avatar
I have all Founders pieces too and there is very little NVH increase if any at all. I had some at highway speeds, but I was due for tires. Got those and it felt much better. Absolutely no noise out of the 3 piece LCAs and PHB. I got the adj PHB with the rod/poly combo. I've had them on the car now for about 3 mths. My car is a DD too
