High speed braking problem...
This spring I lowered the car and it seems like after that, if I am going around 70 MPH and hit the brakes hard, the pedal somewhat feels like its pushing back at me for a sec and then it starts to brake.
At normal speeds I never have a single issue
I am wondering if possibly my brake booster is going? I still have to take off the wheels and check everything and make sure none of my brake lines are somehow kinked. I also notice that my rotors in the front have divided colors right in the middle of them. One ring is like a very very faint tint of blue on each rotor? I have never noticed this before.
Getting the driver side strut out can be hard because of the torx bit under the master cylinder. Maybe when I was messing with the master cylinder a little bit to clear myself some room I could've messed up the seal behind there that goes into the brake booster?
Replaced the hub (which fixed the ABS issue) and the problem went away.
The best way I found to counter the problem was squeezing the brakes instead of slamming on them.. which is something they teach you in various performance driving schools.
Be sure to inspect all your hard and soft lines, I upgraded my soft lines to stainless steel braided Goodridge lines...
Also, did you follow Hawk's burnishing process?
"1. After installing new brake pads, make 6-to-10 stops from approximately 30-35 MPH applying moderate pressure.
2. Make an additional 2-to-3 hard stops from approximately 40-45 MPH.
3. DO NOT DRAG BRAKES!
4. Allow at least 15 minutes for the brake system to cool down."
So I'm thinking i'll start by scanning for ABS codes and probably changing the ABS wire that goes to the front left hub assembly, and inspect the brake lines down there and go from there
The diameter is 25.7" in the front and 27" in the rear. Is that enough to mess with the ABS like that?
The day I put the 285/40/18's in the rear the car was seized from me for something I didn't do. It's a long story. So I don't know if it would've been like it ever since that day or if it's something after that fact, 7 months later when I finally got the car back and able to drive it again and lowered it and stuff.......
Honestly i've been thinking of getting a new set of wheels all around and might just go 17's all around for better handling and to avoid stupid headaches like this
I bracket race and after every pass, I feel it
