Fbody suspension on unprepped surfaces
I have an '02 z/28 that I race in a quite a few unprepped track events and what not. I'm curious what are the guys that are racing in unprepped events an street racing doing on the suspension to get it to bite more. I can go to any regular prepped track and 1.44 60' off of the trailer, but these unprepped surfaces it MIGHT 1.7-1.8 if I'm lucky. Usually I lay out vht if allowed or pimp juice also. Suspension is as follows on a 275/60/15 Mickey pro radial:
Umi tubular tunnel mount torque arm (adj)
Umi tubular control arms (single adj)
Umi tubular panhard bar (single adj)
Umi tubular sub frame connectors
Bmr 1" lowering springs
Spohn drag sway bar
QA1's 12 way adj on all four corners with drag springs up front
Spohn drag sway bar
LS1Tech Premium Sponsor
As the axle tries to wrap under load, the lower control arm being at a downward angle will now be lifting against the weight of the vehicle which will essentially drive the tries into the pavement. If the arm is straight or running upward, it will actually unload weight from the rear of the car and cause wheel hop. This geometry works the same no matter if the car is lowered or stock height.
This helps me out a lot, braidington never preps the track on a street heat night so the next even I should hook up better now. What about the ta? Can I adjust that too to help hook on unpreped track?
