Can a camaro be built to out handle a c6
#101
Actually the setup we've been testing and working on with UMI has AFCO shocks, they are undergoing one more round of tweaks, but I wanted them on Hypercoils which is how I'll set mine up and that's what I've been driving on.
I have to find a car first, then decide what to do on the dampers and springs. I know how my stuff works, and it works well enough to win ESP National Championships, but I've prove that already. I probably would not run the Ridetechs on my own car because if I went coil-over I'd likely run what I've been working on. If said car has Koni's and my springs on it, and the one I'm looking at already does I might stay there for the time being.
There are benefits each way, and I kind of like kicking *** on things that sometimes folks isn't fancy enough.
UMI certainly is.
#102
For reference I have less front camber in the Z06(-1.3) as I did in the Camaro(-1.8).
Here is the chart. I am on the second alignment, Performance street/track on street tires. Some reason I thought I was on the third one down...I street drive too much for that one....although I may buy camber plates/blocks and start setting my own toe.
#104
well I don't know I'd call it anything special. I mean it's not any different than all the years I have given out specs based on use. I'm not just as much into marketing. Then again I haven't gone bankrupt.
__________________
#105
Back up again, I am getting my brain wrapped around the cars capabilities. The car is on race takeoff slicks. It has Pirelli on the rear and Continental on the front...........long story.
For reference the best I ran in the Camaro on 5 year old(new) BFG R1's was a 1:59.8 and I only did it once. I was a consistent 2.00 lapper on that setup at NOLA Motorsports Park.
Best so far in the C5 Z06 is a 1:54.2, car is still stock but has more camber now with -2.3 front and -1.2 rear. Suspension is bone stock, brakes are stock but the front have DRM stainless pistons, engine has exhaust/intake/tune. I raised the car back up also, it turns better with more shock travel. It's almost at stock ride height now.
I will go quicker with more seat time.
I need to be on track with STi Killer, that would be fun.
Tires are warm at about 4 minutes in.
