adjustable panhard bar - needed when lowering car?
I am lowering my 1999 Camaro SS, and wanted to know what other components MUST be changed to properly lower it?
I was reading that the rear end will shift to the left when lowering the car? Therefore I need an adjustable panhard bar to bring it back to the center?
Also which Panhard bar to go with, I see a lot of choices?
Yes, you need an adjustable (or shorter) panhard rod, or a watts link. I got mine (Panhard rod) from Founders Performance. Love it. You will also need springs, shocks, and an alignment at a minimum. To prevent wheel hop you will also need LCA relocation brackets; Founder Performance is where I got those too.
absolute bare minimum is shocks, springs and panhard bar (or watts link), I went with founders, and an alignment.
once all is said and done if you experience a vibration that was not there before then you could need an adjustable torque arm to reset the pinion angle and depending on mileage you may want to do control arm bushings and ball joints while everything is apart. Also you may as well do relocation brackets while you have the rear control arms out for bushing replacement (or control arm replacement if you decide it's easier to replace the rear control arm then press in new bushings on the old ones).
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
Still, for under $100 for an adjustable arm it is a good idea to just plan on it.
LS1Tech Premium Sponsor
I would recommend our BMR on-car adjustable panhard bar with polyurethane bushings. It is by far our most popular adjustable panhard rod we offer and would be perfect for your application.
BMR on-car adjustable panhard bar (PHR002)
![](http://www.bmrsuspension.com/siteart/products/PHR002_large.jpg)
If we can help you out in any way just let us know.
__________________
Glenn ***
Sales Tech
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
