18 inch wheels causing abs problems?
I dont have any abs lights on or low trac light, basically it feels like the brakes are really tight and barely work unless i press really hard and then it feels like im getting weird feeback in the pedal and some strange noise. Can someone please help me out, its pretty scary when it happens.
if the tire sizes between front and back are to far different (like the stock C5 tire sizes are very different) it can play havoc with the ABS.
https://ls1tech.com/forums/wheels-ti...bs-issues.html
https://ls1tech.com/forums/wheels-ti...f-asr-abs.html
site:ls1tech.com
at the end of the search bar.
For example in this case you would type:
staggered tires site:ls1tech.com
into Google
Also in your case a 275/35/18 for the rear tires would be the right size, that puts you at 0.1" difference in diameter which is less then 1/8th an inch
