chunk of LCA bushing fell out!!!! what to do???
i had the car up on the lift today about to grease suspension, well, when i got to loking i noticed that a piece of the bushing on the back mount on the driver side was coming out so i pulled it a little and it just came right off....about a 1/4 of the bushing itself...actually it was probably 1/8th. anyways, what do i do? just order a new set for one side, or is it something i should do all 4 at once? thanks for any info.
Matt
Matt
Moderator
You need a good arbor press to change (stock) LCA
bushings. Dunno how tight aftermarket ones are.
I bought a Harbor Freight standup press. If you're
talking stock here, might try the 1LE solid rubber
ones for a bit less squirm.
