Pinion Angle... again
I am using a magnetic angle finder... I'm using a straight edge as well.
So, I understand the need for around a 2 degree different in the angles of the driveshaft front to rear, with the trans being greater by about 2 degrees than the rear. Wonderful.
Now the question is, how do I get accurate measurements for those two angles?
I am putting the straight edge on the crank pulley and measuring it. It looks to be about +2.5 degrees. Now where is my second measurement? Is it the driveshaft itself? Do I put the straight edge against the trans edge where the driveshaft slides in? Do I measure the u-joint?
Same for the rearend. Can I use the bottom of the pumpkin? Or the bottom of the torque arm bracket? Then do I take the second measurement from the driveshaft or somewhere else? Also, does it matter if I'm measuring on the x or y axis? With the straight edge on the balancer, I'm measuring it's relation to 90 degrees on the device and is essentially a y-axis measurement.
My angles are as follow:
Front of crank is +2.5 degrees (pointing down)
Driveshaft is -1 degrees (pointing up)
Rearend (measured off the flat bottom of the torque arm mounting bracket) is -1 degrees (pointing up).
So does that mean I have 3.5 degree front angle and 0 rear? Which means I need to adjust the rear to shorten the TA? Initial measurement was 0 and 0 on the torque arm bracket and driveshaft. Meaning I was at 2.5 and 0 for a 2.5 degree difference...
Is the torque arm mounting plate a good place to measure?
Hope that helps! I think the Pinion angle discussion is so frequently over-analyzed. Often times at the shop we'll throw it together with an approximate pinion angle, drive it and adjust accordingly. Every car reacts differently, so to go for an exact number isn't always going to be ideal.
