First time replacing shocks. What else to replace while they're out?
My question to you is that what in the heck did you do to break off the top nut off your old decarbons???
as for the nut on the top of the original shot, I used my dremel to hack away the nut along with a chisel and impact wrench. It took about an hour to hack it away. I can't tell you how much I hate beating on a spring compressed that much with fear that it will fly apart.
I do also have an issue with the STR.T rear shocks. There is a spacer on the KYB shock that pushes the lower shock mount about 3/8" forward of the rear end shock mount. The STR.T does not have this, and the installed shock just doesn't look right to me. The supplied bolt looks to be long enough for me to put in a spacer - thinking of one of the nuts off the old shock. Also, since I replaced my sway bars, it seems to me that the sway bar end links are too long such that the lower end of the link is actually lower than the bottom of the lower shock mount (with the ends of the bar pointing downward). I have a spare set of Moog rear sway bar links, so I'll look to see if they are a different length (I cut the old ones out and may have tossed them so I can't use as a reference).
These STR.T's better be good considering all the frustration you have to go through! I hate that there are NO instructions to be found
I sent a message to Koni asking for assembly instructions, if they get back to me mabye they can answer that question as well.
