Just a little interesting teaser shot from the BMR Development room
I see a watts link and what I will call "3 point +" subframe connectors that actually tie into the rear frame rail. I'm assuming the torque arm relocation/tunnel brace is a product already available, if not that too.
LS1Tech Premium Sponsor
The subframe connectors can either be welded or bolted in depending on how the end user wants to install them. The torque arm is a new item also which provides more instant center adjustment than any of the other ones out on the market. It also use BMR polyurethane torque arm bushing that our full length torque arms use which will ensure that it is quieter and will have better drivability than the other tunnel brace available out on the market.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Sweet, like me some development and that watts link is calling my name...
Looks like you upgraded and reinforced your torque arm too with interlacing tubes between the top and bottom of it?
The new BMR tunnel mounted torque arms will be braced like our more drag race oriented xtreme torque arm so they will be very strong and will be able to take anything thrown at them. These new torque arms are 100% bolt-in unlike our current shorter style torque arms which need to be welded in. Also the new BMR tunnel mounted torque arms have a integrated bolt-in driveshaft loop for safety.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
The watts link should be ready soon, we are just waiting for some of the parts needed to build it to come in.
We are doing our best to come out with new and innovative products for everyone.
Thanks!
It is definitely exciting as we will be releasing quite a few awesome new products over the next month or two.
Thanks!
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Also, for those who may not have caught it at first, Look closely at that crossmember for the torque arm. Specifically around where the exhaust crosses
That is one thing!
He is really talking about the crazy amount of ground clearance and exhaust clearance that is available with our new tunnel mounted torque arm.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Super Hulk Smash
Does that Watts link clear true duals... lol
It looks like it wouldn't, because it occupies the same physical space in front of the gas tank as the drive exhaust pipe and who knows if it clears the pipes as they come over the axle. I will say the BMR PH Bar Relo kit does an excellent job of clearing the duals.
Our BMR panhard relocation kit definitely opens that area up quite a bit allowing the room to run a decent sized exhaust over the rear end.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
