Anyone use Hawk Street/Race pads
Has anyone run these yet? These are new to the Hawk line up and are marketed to be a bit more aggressive than the HP Plus pads.
Heading to the track next week (road course) and am contemplating trying them.
http://www.hawkperformance.com/perfo...ce-street-race
LS1TECH Sponsor
I have not, but I will be carrying them. I'm always dubious of claims that a brake pad can "do it all". Because well, they usually cannot. The two closest I found are DS2500 Ferodo's and EBC Yellowstuff, but neither of those I'd call race pads, but more "track day" pads. But it's gets more confusing because Hawk also claims the HP Plus is suitable for that use... and it's not.
If you want to try a set let me know. I am waiting on pricing now for those and I generally can sell Hawk at a price that I'm not allowed to advertise.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
I highly doubt it's possible to get you any before next week. I don't even have pricing, and I deal with a huge Hawk distributor daily and they don't even have pricing.
FWIW, they tell me they've heard they are similar to DTC30 which I've used. In fact I ran a car on some this last weekend (a Gen 5 @ PittRace in the Optima event). I would not recommend those for almost any track use, and if these are similar with a street angle, no way could I recommend them.
If you want to talk options and compare to what you've been running up to now, give me a yell.
Sam
Sam
__________________
LS1TECH Sponsor
Found out some other things. Friction code is the same as HP+. which have power but it's abrupt. The DTC30 are actually more linear then HP+ and of just those two I'd prefer the latter... but not for hard track use, they just don't hold up.
Here's a pic of me this weekend. It's UMI's car. We are working on some development parts and those pads were on it:
I guess this should serve as a gentle reminder of how some of us do more than cruise around in cars.
__________________
LS1TECH Sponsor
I can get you pads in time for the weekend, still, if you need some.
__________________
What's the consensus on HPS or HP+ pads for monthly autocross events and 90% daily driven?
I currently have unknown pads with slotted/drilled rotors on LS1 brake swap on my 95 Z28(bought setup used). I'm not too concerned with brake fade as I am with picking the right pad that does not need to be HOT to work correctly.
The HP+'s will squeak kind of loudly coming to a stop every time you do until they get warm, so expect some noise from them ....and looks from others at red lights and stop signs. If you're competitive in Auto-x, get a set of the HP+'s just for the events and run the HPS's on the street.
I bought the drilled/slotted rotors+matching pads + LS1 calipers + SS lines as a package used from a member here. They have been sufficient for me just getting into autocross for my first season.
I do plan to dump the drilled rotors and go with blanks or slotted at most.
I like the confidence that even the LS1 brake swap gave me with no name rotors and pads. Having said that, I would like to see what some decent pads can offer and will most likely go HP+'s
LS1TECH Sponsor
Between just those two, I'd do HPS. But you might well want more power than that. I've been back to playing with pads again lately on my Corvette. I really like EBC Yellowstuff. Similar power to HP+, and still dirty and can make some noise, but MUCH more linear in their torque curve. And they work cold.
I have EBC's, I have Hawk, and a number of other brands as well so I can offer you what I think will be best, not just one brand.
Drilled rotors aren't good, they will crack. Slotted is ok, and in fact in some cases where there is a lot of dirt around we find slotted rotors are less susceptible to grooving. They don't stop any better, but they wear better in that way. Again lots of options there.
__________________
Thanks a lot Sam. I came across a recommendation for some Ferodo DS2500 pads that are supposed to be similar to HP+ pads with less noise and dust? Any experience with those?
Come christmas time I will be giving you a call for a differential and some pads+rotors for next season.
Super Hulk Smash
When I was looking at pads, I had it narrowed to the following:
Hawk HPS - what I went with. I had on other vehicles. On the street and when cold it's hard to beat. Crap at the track. Doesn't take heat and fades. But you never get to that level unless you are driving down a mountain on the street. Lower .40s in the coefficient of friction. But they don't squeal and the dust isn't bad at all. When you really stand on the brakes, they work with street tires and the F-Body brake system well.
Ferodo 2500 - wish we had for the stock F-Body calipers. I'd have run that. Upper .40s in coefficient of friction.
Porterfield R4S - Almost pulled the trigger on these. Have heard a lot of good things from BMW guys on their streetability and even track day duty capabilities. One draw back was cost and some poor reviews when used on other braking systems. Close to .50 coefficient of friction, linear, and good thermal range. I also think they don't squeal or dust terribly.
EBC Yellowstuff - Seemed to be a bit hit or miss from folks on how it worked. On the street, it needs a little heat to work well, and at the track can fade out and wear VERY quickly. Higher coefficient of friction. Close to .50-.52. Apparently they don't dust or squeal bad either.
Carbotech AX6 - I spoke directly to Carbotech about this. These were the most interested pads I looked at. They dusted and squeaked a little more than some of the others but had higher Coefficient of friction that HP+ and were more linear. Carbotech actually recommended XP8/AX6 combo front and rear. It was like $350 vs the $139 for the HPS. For a dual purpose pad setup that might give up a little on the street, that's probably the strongest combo. XP8 is in that .52-.58 range and the AX6 are closer to .50.
LS1TECH Sponsor
DS2500's rock, but no F-body pads. Just C5 pads.
R4S's are more hype than anything and in times past saw other pads in the boxes, and sometimes different pads for the very same car.
EBC Yellows are what I have on the Z06 right now. First time I've used them personally. They are not clean, slightly less bad than HP+ but they do stop. They take a while to bed in and work their best. But have a very linear curve and feel good. Have been recommending these from time to time.
__________________
Main differences between the C5 calipers and LS1 calipers that I have found are:
40mm piston on C5, 45mm piston on LS1
Pressure cast C5 vs gravity cast LS1
additional cooling/strength ribs on C5 caliper
~1" larger C5 rotor vs Ls1.
Already having LS1 setup, to feel a real difference I may wait and long term go to the CTSV front setup and run 18" wheels instead of going with the C5 swap.
But aside from that, is it possible to run a C5 pad in a LS1 caliper/rotor? I would try it, but I don't have any used C5 pads laying around lol. That way I could run the DS2500 as a drop in pad...
I have read of people using Z06 calipers with LS1 rotors and pads.
Info I came across here post#10:
http://www.pro-touring.com/threads/5...nd-C5-calipers
LS1TECH Sponsor
the C5 and F-body pads are similar but not the same.
Frankly if you were to upgrade again I'd recommend a Wilwood kit. First because it's an engineered kit which doesn't need to play with spacers, etc. But also because they come with two piece rotors and pad availability is good.
__________________
As far as pad selection goes for the guys that actually beat on their cars, check out carbotech. I've used most of the common track day pads and the carbotech blow them away. They never give up, seem to be much easier on rotors, and the dust is easy to clean up and non corrosive. Another benefit is their street and race pads are all compatible. No need to re-bed or switch rotors going from street to track pads.
