Founders Adjustable Torque Arm questions?
Hello all,
Im looking to purchasing a torque arm and relocation bracket from founders. Well I have seen a few posts talking about this relocation bracket but no bracket on their website.
I was also told by them that :
"Our torque arm axle mount has two sets of mounting holes to accommodate aftermarket rear ends including the Moser. You may have to cut the outer set off to use the inner set but it will work. If your factory torque arm clears the true duals ours should fit as well."
That being said Im curious who purchaused this and had to do that I would like to see pictures. Thank you!
Founders doesn't make a torque arm relocation trans crossmember. I have their TA with a Strange S60. I had to cut off the first set of holes on the top of their TA bracket and use the second set of mounting holes. Otherwise the TA would stand too far off the rear diff. See the pics in this post I made. https://ls1tech.com/forums/suspensio...l#post18280419
Also Strange has some torque arm install instructions that may be helpful.
http://www.sjmmanufacturing.com/Stra...g-warranty.pdf
