Suspension for 2000 firebird
Stock right now. I was stupid and didn't order the Viking coilovers during the Black Friday sale. I am going to get them, but will likely just buy the fronts now and eventually buy the rear coilovers later. Either way, after a lot of research and talking to people, at least I'm 100% sure I'll be running the Viking coilovers.
For 2 vs. 3 point - depends on your torque arm. I like my customers to have the 3pt with a short tunnel mount torque arm to help distribute the load on the floor. The 2 point is sufficient in most applications. Also choose with your budget in mind.
If you have any more questions call or email, I'd be glad to help.
Shocks are indeed one of the most important parts of the puzzle, but keep in mind not all people's needs will be covered with one particular brand of shock or suspension package.
There is a lot of debate on SFC and I can go on and on about it. Best thing I can recommend to you is that you buy a true subframe connector, not something that bolts to your suspension mounts and then doesn't even contact the actual subframe of the car. We can elaborate on that more later.
Best thing to do is give us a call and we can go over your needs and work within your budget and time frame. Spend your money right, and do it right the first time!
As for the other components, we have a new "modular" system with a 4 point Sub-frame connector and short-style torque arm. This is a solid system that ties the whole underside of the car together really nicely and adds a tremendous amount of bracing and strength. Our new torque arm eliminates virtually every problem normally associated with a short torque arm and really is a universal solution. I can work you a pretty good deal even without it being sale time. Good enough you may not have to wait for a holiday sale. Here is a picture of the new system we have. Look it over and give me a call and we can work some numbers and see what I can get you set up with
Sorry I just saw this and ill give a call soon. but all I need to know is, what I need to do if I get a 9 inch. I plan on getting one soon and I know it messes with the torque arm and driveshaft and stuff. also I have a y pipe as in the picture so I wanna know if a relocationed torque arm would be even a option.
If not, are they on the 2015 agenda?
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
