starting to rust!, Will stainless work?
Old May 29, 2004 | 01:14 PM
99whitews6's Avatar
Default starting to rust!, Will stainless work?
My longer LCA bolts that were installed when I put my subframes in are starting to rust. Are stainless bolts strong enough to work here? From the local hardware store?
Old May 29, 2004 | 03:57 PM
DARK AGE 53's Avatar
I believe the grade rating is a little different on stainless, check with a Nut & Bolt or Fastner supply store to get the correct grade needed.
Al
Old May 29, 2004 | 06:30 PM
99whitews6's Avatar
Anyone offhand know the length and diameter of the longer bolt needed to go through the LCA's and BMR subframe connectors?
Old Jun 1, 2004 | 01:12 PM
99whitews6's Avatar
TECHNICAL SPECIFICATIONS
Screw Type Cap
Length (In) 4
Thread Size 1/2-13
Thread Type USS Coarse
Box Count 25
Height (In) 5/16
Head Type Hex
Thread Length (In) 1.25
Material Stainless steel
Width Of Hex Head (In) 3/4
Max Core Hardness B95
Min Core Hardness B85
Tensile Strength (PSI) 90000/125000
Does anyone think that this bolt is strong enough to replace my lower control arm bolt?
Old Jun 1, 2004 | 09:03 PM
jimmyblue's Avatar
Moderator
Tell you what, when I installed my cutout I hand-
sheared off about half of the stainless bolts I used,
skinny ol' me and a 1/2" ratchet. They are like
pudding, those Ace Hardware stainless bolts.
Not To Be Relied Upon. Better to get some anti-sieze
(for the thread rust) and just wipe it all over the
bolt w/ a paper towel, everything will now be nice
and silver. Stay that way a good while, too, and
if it gets a little crusty, just wipe it on again.
Seriously. Suspension deserves proper grade bolts.
Old Jun 2, 2004 | 09:00 AM
eswolfgang's Avatar
I believe a 10.9 or grade 8 bolt is 130ksi yeild stength, I assume by your listings it is 90ksi yeild and 125ksi ultimate for the stainless, in this case they are not equal to what you have, I assume the bolts now are 10.9's or grade 8's
