Deleting ABS
I would love to be able to fix the problem, but from what ive read about people having all sorts of problems after they change tires or rear ends I may just have to delete it. So again, why is the kit necessary? Is it a brake biasing thing? Mine seem to be fine.
but like I said the kit isn't necessary. Pulling the fuse is basically the same thing.
The connector on top of the abs module under the hood, pull the light green & yellow/black wires out, snip them and ground them. That will turn the abs light off, and the brake light off.
Staggered width tires will not cause abs issues, different diameters will. You have some other issue preventing your abs from working correctly.
