Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro and Firebird CTS v Brake Install with Pics<br>Step by step instructions for do-it-yourself repairs.
Ctsv 6piston brake swap issues
Ive been working on my ctsv brake swap that I originally saw on gm high tech. So I bought all the parts that they used figuring that there would be no issues. I read some of the concerns of the z06 rotor size being an issue but never saw any hard evidence of it. But after finally installing the brakes on my car its apparent that the z06 rotor is way to small. the brake overhang on the outside is atrocious.
Ive seen acouple guys on here do the swap with the gen5 brake rotors with good success I think. But all of the gen1 V guys and the gen5 camaro guys that do this brake swap are all using the ctsv rotors with the swap. So is there a reason I cant use the ctsv rotors for this?
Has anyone done this swap on a 4th gen with the ctsv rotors? anyone have any measurements that can throw at me?
Id like to be sure of proper fitment before I go waste my money on more rotors again lol.
Heres some pics of the rotor fitment and some measurements I could find off a 5th gen with ctsv rotors.
Ya its just the angle of the picture making the caliper look like that on the rotor. It is centered... the issue is on the second picture if you look closely you can see the brake pad over hangs the caliper by probably 1/2 and inch. Due to the fact that the diameter of the z06 rotor is just to small for that caliper. I dont understand how people run this setup with improper brake/rotor matching.... anyways enough rant im just trying to figure out if anyone has tried running a ctsv caliper on this set up.... if only i could borrow one to see lol
https://ls1tech.com/forums/suspensio...-calipers.html
I used Camaro SS rotors and then had the centers of them bored out to match the stock rotors holes. They fit perfect. I didn't use the Z06 rotors due to the same rotor being used on both sides and I wanted the caliper to fit perfect. Also because the Z06 Rotors do NOT fit perfect with the CTS V 6 piston caliper as you found out. They work yes, but the pad wear will be uneven. ONLY the SS Rotors do.
As far as the CTS V rotor... I've not seen any build use them. I wouldn't chance it and the SS Rotor is just as nice. You can get the SS Rotors for about 70 bucks delivered for one piece or find a nice set of 2-Piece at any vendor on here. Any shop can bore the rotor out fairly cheap.
Here is my install I did last month.
Hey ya you were actually one of the guys I was talking about with the SS rotors lol. I wasnt so much interested in ctsv calipers as I was to the rotor diameter and which of the 2 (ctsv or SS) fit better. I dont know the actual difference in size between the 2... I dont think they are that different.
Do you have any pics of the rotor at the top where the brake meets like my #2 picture. I just wanted to see how much rotor you had over the brake pads.
Thanks for the help
Thanks for the help
Thanks for the help
Also you cannot use the CTSv rotors as the lug pattern is different. From what I have read, I would go with the SS rotors. I have the gen 1 4piston calipers with Z06 rotors and have alittle bit of overhang, but car has been driving fine for the last couple of years, I do not track it though.
I'd love to try the ctsv calipers just to try and see if they work but I'm not going to fork over the money to get my hands on one... Since other guys have used the SS rotor with success I'm leaning towards using it anyways....
Now that leaves me with some brand new z06 rotors I need to get rid of if anyone is interested
Thought I'd give an update on my delima. Since after measuring I saw no reason the ctsv rotors wouldn't fit I went ahead and bought a pair. And they fit perfect!
So for future break swappers. If your doing a 6piston ctsv swap use the ctsv rotors! The pad and rotor meet perfectly and fit on 18inch wheels. Ill do a full write up when I'm all done just thought id sum up my delima.
Yes hub needed machining a bit from the machine shop the hubs between the ctsv and 5th gen camaro are the same. And any 2nd gen ctsv 14.6inch rotor from 2008-2014 will work. They're all the same. The brake/rotor contact with the 14.6inch rotor is perfect with the caliper. No modification needed.
Awesome setup, but just to clarify, I don't think those are 15in rotors.
I'm pretty sure they are 14.6in. Same as the ZL1 rotors.
Here is a good reference to all the different size rotors available from GM.
http://lukeskaff.com/?page_id=333
Centric also lists the rotor as 370mm.
I'm curious because I'm looking for a 15in rotor that I can bolt onto my C5. If that is actually 15in it would save me a lot of money.
You didn't happen to measure it did you?
Ya looks like your right. I'm pretty sure i read my measurements off of Wikipedia or something which would explain why it was wrong lol. Glad you caught that so I wouldn't keep spouting off wrong rotor sizing. Yes they are identical to zl1 set up. They are just gen2 ctsv rotors and brakes.
Here it is. Great write up. I followed everything they did to the T and used all the parts and brake lines they used. But as you've seen from my trials and errors. Do NOT use the z06 rotors. Use the second gen ctsv rotors and you'll be golden.
