Installing Panhard Rod
Thanks!
While I had the passenger side jacked up with the rear tire off to change the control arm I removed the upper bolt for the panhard then slid in under the side of the car that was on the ground and removed the lower bolt, then when installing the new one I put the top bolt in and extended the length of the bar till it lined up with the lower hole. If you have access to a set of ramps you might be able to just back it up on them and do it all right there without jacking up the car at all.
I'd remove the passenger side bolt first when removing the old, and install it last when installing the new phb sine the passenger side bolt is a lot easier to see and access.
