Just installed an S60 and curious as to which LCA mount hole to use.
Hey everyone, I just installed a new S60 which I suppose was just recently changed to house 4 lca mount holes instead of 2 (maybe even just 1?) But I have my suspension all stock still to keep the noise down.
With my new 4.10's, traction isn't spot on but I currently have the LCA's in the top mount hole and I've been hearing around that the bottom hole is the best? I have some UMI non-adj. LCA's on the way but would everyone be in agreement that the bottom hole would be the best bet for traction?
Thanks!
Thanks!
Just make sure with whatever hole you decide that the wheels don't move too far forward in the wheel well. The lowest hole would provide the most forward traction, but for street driving aim for level or slightly lower in the back.
Like Ramair said use whichever hole gets the lca level or use lower holes on the rear to get better traction at the trade-off of a harsher ride. I have BMR relo brackets on my S60 and use the second hole down from top. Make sure to do the hose mod to avoid the rear of your car sitting higher from the larger axle tubes and corresponding higher spring perches.
