Bilstein Level 2 and Red Eibach springs
Decided to change out the struts on my 96 Z28 after they started to ride like crap. The previous owner threw on the red Eibach lowering springs and didn't change the struts. I decided to go with the SLP Bilstein Level 2 shocks for the front and rear and wanted to know if they are compatible with the red springs. The package SLP sells with springs come with the black springs, but I do like the look of the aggressive red spring drop. Will I damage these new shocks or will I be fine?
Either way to answer your question the shocks will not be damaged at all, worst case scenario they will just not last add long as intended.
http://m.summitracing.com/parts/eib-4-3138
Ugh god sportlines? Do yourself a favor and throw those in a burning trash can so no one else can mistakenly use them.
One of the worst springs for these cars, the terrible ride quality is mostly from these springs, way too low for the spring rates causing you to slam the bump stops hard.
Look into strano or bmr, that's the lowest you really want to go for functionality, handling and ride quality.
