Vendor Watts link differences
I sell the Fays2. But I also have USED the Fays2 on 3 cars of my own. If I had a car that could use one now, I'd have it on there too. I just don't because Corvette's don't need a Watts link.
All I know is what works, and what's won a LOT of SCCA National Championships. I also know that some companies like to copy what's out there and pretend they came up with something better. Well, like Steve said double bearings (which the Fays2 also uses) vs. some plastic bushings aren't the same kind of thing.
Remember this thing is responsible for keeping the body of the car located over the axle. For instance, a LOT of load goes through one bolt. I want that bolt to be BIG. In the not to distant past there have been Mustang, S197 model Watts links that have failed. One brand kept breaking center bolts. Another would shear the pivot. But yeah, they're all the same.
Adjustment range is similar, but the Fayes have half hole adjustment, where the MWC is full holes.
The Fayed would be significantly stronger, does it need to be, not sure.
Rod ends are Fayes 3/4" vs MWC 5/8" with corresponding sized hex bar. Bigger ID propeller bearing. A lot more steel in the Fayes. I would guess it weighs 40-50% more.
We will find out, hopefully not the hard way when the MWC unit and diff get tried on 160mph 1G sweepers. I hope they know their engineering **** or this could be be those famous last words.
Car is mainly used for autocross/weekend warrior.
