Vendor Watts link differences
https://ls1tech.com/forums/gears-axl...l#post15495183
Did some weighing to see if I saved some weight, I was happy that it will knock 47.5 lbs out of the weight of the car. Not as much off the diff as I would have thought, but I had heard the Wave Trac was heavy.
BTW my set up is:
Alum Center
Wavetrac
35 spline
reinforced back brace
tow loops
Watts
4 ch. ABS rings
powder coat
I am sure a spool, 31 spline alxes and no back brace would be much lighter, not sure what the 10 bolt weighs, or a old style Moser 9".
Moser 12 bolt, 212lbs + Fayes Watts, 26.5lbs + Torque arm, 30.5lbs for a total of 269lbs.
MWC Fabbed 9", 192.5lbs + Watts, 11.5lbs + Torque arm, 17.5lbs for a total of 221.5lbs.
It seems like it would be possible, you just would be getting rid of the axle clamps.
I don't see how saying "Our watts link allows you to lower the roll center 2" below a PHB" is divulging any critical information. It is not proclaiming anything better/worse than any other watts link out there. Hell how may times have you even been asked that question? LOL
Anyone with one of your watts links could give us this value after the install. If 79 T/A is "interested" in your piece and you tell him the value, at which point he is not happy with because it is not sufficient, will you get mad because he didn't buy it?
I apologize if this comes across as an attack. That is not the intent, the reason behind withholding the info seems odd that's all.
One issue we have here is that roll center is depicted by ride height. So relative to what measurement we start with will change the amount of the available difference. Say the MWC Watts link can lower the center by 3.75 inches at stock weight and stock springs. Next guy has coil-overs and lowered 1.25 inches measured at wheel opening, and weighs 200 less. Now we are only at 2.5 inches of available change.
What I will tell you is that there is 3.75" of adjustment height for the propeller mount(direct roll center point of a Watts equipped car) that should cover any available ride height of a 4th gen car. Of the cars we have done installs on the propeller setting ended up just over the middle of the adjustment range.
