Viking Shocks, Settings?
They say c3r6 is almost exactly like a bilstien shock. However I obviously have a softer spring. My impression was the ride was soft and compliant but would bottom out if not careful. It rode really similar to bilstiens, as expected.
Basically for me, an auto on a radial tire I'm gonna try f c15 r0 and R c14 r 7. This rear setting is obviously very different from viking recommendation. Both Midwest and some others have recommended I need more compression control with the radial. At first I had it r c2 r6 based on viking paperwork.
You may need to reread without wishful thinking. They said with those settings on the warrior shocks that the dampening rate was similar, but the curves were different, which will lead to different feel and performance.
Hey JD.
Can you forward me the damping curves for Koni's et al?
ramey@umiperformance.com
Thx
-- Ramey
Thx
-- Ramey
Hey JD.
Thx
-- Ramey
Thx
-- Ramey
What was stated was, at c3r7 the shock was closest to a bilstien hd, as compared on a shock dyno. Admittedly, I don't really know a ton about shocks, and shock dynos. What I noticed was at c2r6 the car rode very similar to the bilstiens I took off. For someone who didn't have bilstiens to take off this may be very relevant information, as lots of people are simply looking for a starting point to try out. At the end of the day I'm not really looking for a compliant ride. 10 months into the year and I've probably only driven my car 250 miles this year.
LS1Tech Premium Sponsor
Stiffening the rebound and compression up will definitely help keep the car from squatting.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
#32
I really don't think a lot of people realize how important it is to have adjustable shocks for drag racing. They really make a huge difference as far as traction and consistency goes.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
#34
You have to keep in mind shock settings are going to vary from vehicle to vehicle, tire to tire, track to track, temp to temp. It is not unheard of to change shock settings every time you go to the track.
Having starting points is great but no way can someone be dead accurate on settings, the only thing that will tell you the proper settings is making test hits over and over again.
This is why we give suggestions and then ask our customers to give us good video and we can give better advice from there.
#35
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Ok, now lets talk street settings for cruising.
After a 3 hour drive and bouncing around like jeep, I'm thinking I may need to go back to the Koni's.
Front 350# springs and Stock Rear Springs - How do I keep this things from riding like a bucking bronco or the ricer bounce?
I want to hear from those that don't just drag race.
#36
#37
ramey
#39
