Viking Shocks, Settings?
I can help you with your settings.
For drag racing you want EZ-up in the front and tie down in the rear.
It always takes some test and tune but you could get started with 8C/2R up front and the opposite in back 2C/8R. Then evaluate the launch and let us know how they're working.
There are a ton of variables but those numbers should get you relatively close.
We dyno tested Viking Warriors against Bilstein HD and found 3C6R to be similar in damping rate even though the shapes of the curves are different. It's just a general indication to get a reasonable street setting.
ramey
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
I looked at your post originally to try and figure out the settings on the DA shocks for the rear, I ended up calling Viking Performance, and they said to start with 2C/8R
