Torque Arm/Long Tubes Question
This car is my daily and I don't beat on it too hard. It's a street car that I'll eventually take to the track, but for now it's just a street car. It has TSP long tubes 1 7/8" and O/R Y. I assume I'd need a torque arm made for long tubes... thing is, I've heard these sit about 2 inches lower than the long tubes. My car is lowered on Strano springs and I already hit my Y-pipe on most speed bumps when I have the unfortunate inability to avoid one every now and then, so getting one of these would make me scared of clearance issues and damaging things. But I also don't want to buy the non-LT version and end up having a PITA installing or having it be impossible. So I'm asking for experiences of people who have been in my situation. I DEFINITELY want one that's relocated as to help protect my trans when I finally get around to going to the track. I want to do things right and protect the car from breaking things as best as I can.
Also... any Thanksgiving/Black Friday sales going on? Torque arms are VERY expensive. (x.x)
I'll let others on here that run our set up tell you how nice it is.
If it's your everyday driver i would stay away from the short tunnel mounted style for the fact they create a significant amount more noise and they don't rotate when cornering like the long style do.
http://umiperformance.com/catalog/in...ex&cPath=7_115
http://umiperformance.com/catalog/in...ex&cPath=7_116
This set-up replaces your transmission cross member with a new stronger set-up with a built in torque arm mount. Each relocation kit is designed to fit a specific transmission and will work with virtually any stock style aftermarket torque arm as well as the factory torque arm.
Our cross member is designed to tuck tight against the vehicle chassis and will not effect vehicle ground clearance.
If you need any info or pricing feel free to contact us here at the shop.
We will be having our annual black friday sale it will start the wednesday before thanksgiving.
Craig
Here is a link to the BMR tunnel mounted torque arms for headers off of our website:
http://bmrsuspension.com/index.cfm?p...productid=1480
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
How's the compatibility with these on rear ends? I have a 10-bolt but I'm eventually getting a 12-bolt. 9 inch is overkill for my uses so I'll probably try to find a used 12-bolt... curious if this product is compatible with any or all 12-bolts.
Our drop down cross member is manufactured to clear virtually all aftermarket header/y-pipe set-ups on the market. It will also clear most merge collectors such as QTP and TSP y-pipes.It does reduce ground clearance, if vehicle has a tighter fitting y-pipe set up you can usually use the straight cross member.
http://umiperformance.com/catalog/in...roducts_id=212
Here is the straight design that will work with stock exhaust or other tight fitting exhaust systems.
http://umiperformance.com/catalog/in...roducts_id=210
If you want to make sure your getting the right product give me a call here at the shop and i can also give you some pricing.
You can reach me direct at extension 101
Craig
Craig, thanks for your help.
Guide to setting pinion angle.
Torque arms are very easy to install but if you have any questions feel free to call.
