poly boxed LCAs, poly panhard, now hear clunking
Just installed new to me but in good damn condition LCAs and a panhard rod. Both polyurethane. Now when hitting small, medium, large, all kinds of bumps I hear a clunking.
Is this because now these areas are solid and another problem is presenting itself elsewhere?
Get under there with a torque wrench and make sure everything is as tight as its supposed to be, even if it feels like its tight, if its not to spec they may clunk.
Edit: Did you tighten everything down with all the wheels on the ground?
LS1Tech Premium Sponsor
It definitely sounded like something was loose from your initial post. Go back and torque everything down and if you are worried about it coming loose you can throw some Loctite on the bolts. Suspension components with poly bushings should be almost as quite as the factory parts if they are installed correctly.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
stock bar had 270k miles. i remember why i enjoyed my other lower mileage z28 so much now
You should see how a halfway decent autocross setup feels...![Icon Rolleyes](https://ls1tech.com/forums/images/smilies2/icon_rolleyes.gif)
Panhard bar was my second mod I did, and I was like "hmm. That right hander felt different, and pretty good." This was right after I installed it lol
leaving my shop there is a 90 degree turn and i took it at 50 MPH like it was NOTHING! and it used to break loose (ive probably taken this turn 1000 times, and that is a realistic number)
and my first thought was.. jesus i could not imagine what an auto cross set up would do, it wouldn't make sense to be able to take turns faster!
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
