Bump Stop Alternatives?
Well now, I've replaced the shocks and springs with coilovers. The coilovers are awesome! But now that the springs are gone, the bags are gone since they won't be retained.
So aside from welding brackets back on the car for factory style bump stops (not preferred) is there an alternative?
Craig
I'm sure this subject will cause major controversy on LS1Tech...lol
https://www.google.com/search?q=shoc...-7CFMQ_AUIBygC
I have shock stops but they don’t work on this car. The rear shocks are too long and by the time they touch it’s too late to help anything. And the shock is mounted in rubber top and bottom. If you hit the stop, the other rubber would just keep squishing instead
First: If you need a longer shock bump stop, just buy 2! If that ends up being too long, then trim down the second one. Second: Factory rear bump stops were a type of foam. Foam is softer than rubber, and rubber doesn't just "keep squishing" either. It's, in a nutshell, a very absorbing high spring rate type of material, in a nutshell obviously. Just find out how long your shock bump stops need to be, trim it to a good length if needed, and you should be fine. Unless I'm completely cookoo myself, that should be a decent way to retain rear bumpstops on the shock body itself
A properly selected shock mounted bump stop will work fine. Not only do they work, but they can be used to tune the suspension.
Another thing- yes, the rubber mounts do compress. Do they somehow disappear as they keep compressing? No, they don't. They will only compress so much, like a shock bumper. Factor in a margin when choosing the correct bump stop for your application. It's not a one size fits all. Can't throw random **** at a car and expect it to work.
The part of the wheel well that has the bumpstops attached is designed for taking hard hits, i don't know if the shock mount could take those same forces.
Are the any coil overs that attach to that point?
After doing what I probably should have done from the beginning (searched!) and taking input from this thread, I'm less comfortable using a shock bump stop. However, the search yielded a thread where a guy relocated his bump stops inboard. I haven't looked under there since seeing that idea, but it seems like the right thing to do... maintain the same style bump absorption, impact the same part of the car with the force and avoid damage to the coilover.
Thanks, everyone!
Yes, but the general practice is to (heavily) reinforce the shock tower mounting surface.
Some of the newer rear coilover kits (at least the handling/road race oriented ones) have a reinforcement 'ring' which is either bolted or welded to that unibody shock tower mounting suface.
If you have no other option then not great is better than not at all. But even if the mounts are cut off, it's not hard to make a mount for a body stop to go back on. A little welding and some nuts and bolts and you're done.
