Pro Fab Tubular K-member is in!
Originally Posted by Inspector12
I've installed quite a few BMR's and I don't know what you are talking about qith fitment cause all of mine went in like the factory K-member with no issues? I even installed one on a car that had been wrecked bad and it still went in with out to much trouble? The BMR had the motor mounts welded in place and they lined up perfect for me? Of course I am sure everyone has there opinion and this is just been my experience with the BMR never had anyone want any other type around here. I have installed them a few different ways but I have done it just like BLT FED with the exception I used a floor jack under the oil pan with a 2x12 under it and I have used the engine hoist too. They all work and I know you said not to leave this to the weekend warriors but Black Beasst did it and if he can any one can with a little time JMO? Good luck to everyone installing K-members and if you need them installed in the Houston area let me know I can do it or anything else for that matter. Seeya!!!!!!!
Originally Posted by BTL FED
The ONLY thing I dont like about the Pro Fab is you have to use your heavy *** motor mount supports (unless they changed this) the stock ones are Iron and weight a TON
Originally Posted by Dear John
What can you replace the stock motor mounts with for weight reduction? Solid, poly?
not the bushings, the physical mounts/pedestals....
you could install something liek the spohn tubular motor mounts...
I, being the owner of a 94 3.4 and still piecing together the last pieces of my LS1 conversion, was totally shocked at the size of the huge motor mounts when they arrived this weekend. I thought to myself "Couldnt I fabricate an aluminum or tubular version of these mounts?"
#33
I'm seriously considering on of these for header clearance/weight savings. I am concerned about using it on a daily driver. Are there any cons in using it for this application, or is this more of a "race-only" mod?
Jeff
Jeff
#34
Originally Posted by BLKWS6
did it come with the bolts that you have to use with it? Or did your stock ones fit?
#35
#36
Originally Posted by P Mack
How much more room is there to drop the oil pan?
#37
Originally Posted by andystang
this may be a stupid question, but do those coilovers come stock? sorry i am an f-body newbie.
#38
Jeff
Jeff
#39
Originally Posted by SSOnYourSix
just go buy 8 bolts/nuts from a local store, they were like 67 cents each or something...
Joe
