What kind of panhard bar?
So I'm thinking about picking up some LCA relocation brackets, LCAs, and a panhard bar for my 98 Z28. This car is strictly a street car but I am looking for grip and do plan on running some 305/45/18s and I've read that with wider tires. an adjustable Panhard does help.
So if I am looking at a low noise solution and don't need every adjustment in the world since this is simply a street car, what kind of bar do I need? The last thing I want to do is spend money unnecessarily.
Usually the only reason to replace the Panhard is for the adjustability and being able to center the rear under the car. (Very necessary if car is lowered)
If you decide not to get an adjustable id advise you to spend the money else where. Chances are you'll need the adjustable sometime down the road
I got the double adjustable panhard bar from UMI with roto-joints on both ends. So far I have been happy with it. There is no change in noise or vibration. I got it because I am about to put on some springs that will lower the car a bit.
We offer a few different variations for panhard bars and control arms
http://umiperformance.com/catalog/in...ex&cPath=7_138
Like mentioned above our roto-joint is a great choice.You get the articulation like a rod end for bind free suspension while maintaining a comfortable ride like Polyurethane.
I would recommend an adjustable panhard bar if you are doing any modifications such as lowering or larger tires. Whether you go with "on car",double or single adjustable is simply a matter of how easy you want to be able to adjust the bar.
If you need any info or pricing please feel free to give us a call here at the shop, We'll be glad to help you out.
Craig
Craig
LS1Tech Premium Sponsor
We offer a on car double adjustable lca's and panhard bar that is heim joints on both ends and we also offer a single adjustable that is poly on one end and heim on the other and I think this would probably be your best option if you plan on lowering your car I would also do some lca relocation brackets. If you have any questions please give us a call we will get you taken care of the with the right parts.
If you are looking for quiet adjustable panhard bar I would look at BMR adjustable panhard bar w/ poly bushings (PHR002) or our BMR adjustable panhard bar with the poly bushing on one end and rod end/heim joint (PHR010) on the other. The BMR adjustable panhard bar w/ poly bushings (PHR002) will be the quietest out of the two options but doesn't articulate as well. The BMR adjustable panhard bar with the poly bushing on one end and rod end/heim joint (PHR010) will transfer a little more noise but articulate better.
Here are link to both panhard bars off our website:
http://bmrsuspension.com/index.cfm?p...&productid=279
http://bmrsuspension.com/index.cfm?p...&productid=281
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Yes Poly will be the quietest but lacks the ability to articulate.
Our Roto-Joints will give you a ride similar if not the same to Poly with the benefit of 28deg. of articulation.
Craig
Craig
Correct and require not much in maintenance if installed properly. You just want to make sure not to crank the bolt down to much when installing them. You need to allow for some movement but no slop from side to side once in place.
However if you purchase from a company that uses a quality heim joint they won't be that noisy either.
Poly is fine for panhard rods. they dont rotate. only move on a single axis. up and down pivot.
now on LCAs i would suggest an end that can pivot, as they need to move and twist in two directions (ie not just a poly bushing)
that being said i run the $47 non adjustable Founders Performance rod (christmas gift)
http://www.foundersperformance.com/p...djustable.html
im lowered with 295s and no the rear end is not perfectly centered. but ive had no issue for the last 12 years racing it that way.
they have a single adjustable for $72
I actually prefer a single adjustable that is not on car adjustable for the simple reason of once the rear end is centered you never have to readjust it again... unless you change the ride height.
I set it to stock length bolt hole to bolt hole.
Put it on the car to measure with plum bobs dropped over the quarter panels while someone is sitting in the car to account for driver weight.
Then measure and adjust the bar to make up the difference of rearend off center.
Also an FYI a poly/poly panhard bar will always try to back the jam nut off due to the suspension arc making the poly bind and twist the bar. Now I always use poly on the body side and a rod end on the axle side and haven't had the jam nut come loose since.
I'm running 315s and lowered on Strano springs. I have a factory panhard bar, don't have rolled fenders, and I don't have any problems. Don't be convinced you NEED a panhard bar just because your car is lowered.
