low profile tire pulls 4th gen all over the road
Is it a common issue that 4th gens pull bad on uneven pavement or the rut in the road if the alignment is off? 1998 Camaro V6 with 275-35/18 tires all the way around pulls really bad on the road, like the alignment is off bad. My 2002 pulls too, just not as bad as this 1998 does.
If it's all in the tires, how do newer Vette's and Camaro's get away with selling cars that pull all over the road. I just didn't know if it was a quirk of these cars. I'm going to take it to get it aligned anyway and hopefully it'll help.
I have 275s on my car and it doesn't pull all over. You'll always get some pull on crappy rutted roads, but if the roads are generally in decent shape but it is still pulling bad IMO you either have a crappy alignment or a bunch of stuff worn in the front allowing it to pull. My 99 has all new bushings and joints up front as of a couple years ago and the pull is pretty minor unless there is a major rut or crease in the road.
I just mounted a set of used Michelin run flats on two of them and put them on the front since they looked the best. My 02 wanders some but this is ridiculous on the 98. Dropping it off tomorrow to have the suspension checked out and a 4 wheel alignment. We just got it running recently. The 98 sat for 7 years and then was bought for $600. We put a gas tank in it out of a 96 Z28 and a brand new Delphi fuel pump and here we are.
If so, although alignment might be part of your problem, I think "the tail is wagging the dog". In other words, the REAR of the car is wandering, due to the mis-match in the tire's construction.
Just my $0.02 worth.......
Having this same issue on my 02 SS. I looked at the control arm bushings and they looked OK. My next best guess was the PS rack so I asked around alittle. the car only has 79xxx miles on it so it seems alittle early to lose the PS rack to me. Tires are brand new 275/40-17 BFG GForce on the front.
