TSP True dual and torque arm issue
Anyone have better pics of the installation of these? I am having issues with my tunnel mount short torque arm (BMR ) lower bracket portion is damn close to the x pipe.
If I drive everything home it seems to make it worse.
Any help would be greatly appreciated
LS1Tech Premium Sponsor
I normally recommend the TA011/TA013 for the TSP duals. The crossmember for those tends to fit better. I had Lonnie at Texas Speed test one of these setups when we first developed them and he found the straight across crossmember fit better and had extra clearance with some shims added. But if you got it to work, that is good. Can you get me pics of what you modified to work with it? Curious to see in case someone else runs into this
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
I have the TA012 mount as i have the tunnel mount torque arm.
I also have a TA013 mount also that was made to try and clear my TSP Y pipe touching issues and some spacers however as low as my car seems to be i would need a lot of spacers its seems to clear the 3" true duals so i went with the TA012 mount.
I was never able to get the true duals tucked up more no matter what i did (could be user error)
I am attaching a picture that shows where I trimmed my TA012 to make it seem to work (still very low in car however I am running my BMR spings)
My pinion angle is approx 2 degrees according to the gauge when adjusted after doing lowering springs.
Let me know if you need more or have more ideas on how to make it work better as currently nearly impossible for me to get out of my driveway.
Rough cut i did
NOTE: I moved my clam shell mount up one set of holes also after this pic was taking to make angle correct on pinion and therefore i have set of holes below what i am using and i believe its one set above. I cut off two sets approx giving approx 1/16" - 1/8" clearance between top of x pipe and mount. It was a little greater than that tell i scraped it putting back in garage
