How would a Koni install cause this??
No don't have pictures as to its a steering feel. Turning both ways my steering goes soft to tight, soft to tight both ways.
I noticed this issue the second I pulled my car outta the bay from putting in the Koni's.
Things I've replaced & wasted money on that i thought was the cause since putting the konis in: new FE2 rack from Delco, new moog lower ball joint, and the pump. I know for a fact it's my install that caused this and not the pump. I must of tightened something too tight or done something.
This car is driving me crazy. The more I try to take care of it the more problems it gives me. I'm losing love for it.
Plus the shocks didn't throw off the alignment since there is no bolts that have to be loosened that have to do with the camber caster and toe in order to install the shocks.
The car is the same height since I had eibachs and stock shocks before. Now I have BMR & Koni. Both are 1.25" drop
do you know for 100% fact that the ride height is the same with the different springs (as in, you personally measured both before & after changing the springs yourself), or are you just going by the advertised drop?
depending on quality control, even 2 "supposedly" identical springs from the same company can cause a difference in ride height, much less springs from 2 different companies.
+1, changing the shocks shouldn't affect anything at all that deals with how the steering feels. Like some of the guys above, I feel like it has something to do with the alignment or a different failing part. You said you put a new rack on it as well?
This started only when i put the shocks in. I didn’t put the rack in until 1 week after i did the shocks. It is weird and can’t think on possibly how a shock can throw off steering feel. Its beyond me and would be grateful for some more ideas.
Note my alignment didn’t move at all when I put the shocks in. you don’t need to looses any bolts that have to do with the alignment when you install shocks on these cars.
I know I won’t get that much more input since no one else has experienced this, but i hope I strike gold with you guys with some more ideas.
When I did Koni shocks with Strano Springs, the suspension geometry changed. Couldn't get a proper alignment, caused issues with steering (similar to your complaints), tire wear, and killed ball joints. I put in UMI upper and lower A-arms which are designed to account for lowered cars, and that cleared up my issues. Keep in mind, Koni shocks cause the front to lower a bit due to different spring perch, which affects suspension geometry. It will affect alignment.
Sure I'll take a snapshot of the printout next time I get the chance to use the rack. But if I recall (and I usually run along the lines of) 0 toe, -1.3 camber, and +5.00 caster. I've ran these exact specs for years and never had an issue. Camber is not too harsh for my Michelin Super sports 255/40 18 up front. Ran these specs on these tires for the past 20k and still have 5/32nds left on the inside belts of the tire. BTW I'm running BMR springs all around (1.25" drop) which are a lower drop than Strano's. I was running eibach Sportlines (same 1.25 drop) for years before the BMR's, so alignment wise im in the same ballpark as I've always been. I used stock spring perches.
