Lowering Question
Old Apr 7, 2016 | 03:56 PM
TransAmShane's Avatar
Default Lowering Question
Hows it going everyone? I have a stock 99 trans am that i plan on lowering with strano springs with koni str.t shocks. I also plan on getting some torque thrust ii 17x9.5 all around with 275/40/17. Just wanting to know if ill be fine or may run into some problems such as rubbing or having to get my fenders rolled?
Old Apr 7, 2016 | 04:14 PM
dojob's Avatar
use this tool to plug in existing wheel specs you have compared to the new specs
http://www.rimsntires.com/specspro.jsp
stock wheel specs are:
16x8 +55 offset
Old Apr 7, 2016 | 04:31 PM
leadfoot4's Avatar
I ran 17x9.5" rims, with 275/40s on my '96 Z/28, and had no clearance problems at all. Coincidentally, I was also on Strano springs. Two things are important...backspace on the wheels, and since you're lowering the car, you'll need an adjustable panhard bar, to make sure the rear axle is centered under the car. If you get wheels with 6.75-7" of backspacing, you should be OK.
Old Apr 7, 2016 | 07:05 PM
Thanks guys appreciate it!!
Old Apr 8, 2016 | 03:44 AM
SteenH's Avatar
Just another reply.
Those tires won't be any problem at all, if the wheel offset is correct of course.
Old Apr 9, 2016 | 09:46 PM
Do you guys think i really need to get a panhard bar? Just trying to save where i can
Old Apr 9, 2016 | 10:27 PM
Darth_V8r's Avatar
Moderator
I'd recommend an adjustable pan hard even if you weren't lowering it
Old Apr 9, 2016 | 10:47 PM
Okay ill do it then
Old Apr 12, 2016 | 09:05 PM
So as far as adjustable panhard bar you guys recommend anything else ill need for lowering it?
Old Apr 13, 2016 | 09:00 AM
blackandgold's Avatar
Over time you should look into an adjustable TA and some lca relo brackets if you want to drag race, but the adjustable PHB should be enough for now.
