ABS inop code 35, where to look?
OP, the older modules on the 93-97 cars aren't really known for that problem. It's possible, but not likely. You'll have to pin out the wiring between the sensor connector and the ABS module and see if you can find a bad connection in the wiring.
Shoebox has a diagram for a 95 on his site, yours might be similar.
http://shbox.com/1/ABS_schematic.jpg
This is the 2nd time this has happened! The black wire had exposed copper at the base and looked like it was heading in the same direction. Those wires are way too thin to be hanging out back on the diff in the wind and heat and all that. Of course Strange doesn't sell it anymore so I had to go on a google scavenger hunt. Luckily I found this thread that had all the answers: https://ls1tech.com/forums/gears-axl...ge-12bolt.html If you run across my thread here in a search, that link will tell you everything you need to know about that sensor.
Using the part number 70085-8080-001 I was able to find a new unit on ebay for $56. It will be here next week and I'm going to inject a blob of clear RTV on top of the sensor so this crap doesn't happen again. Hopefully this fixes the abs inop light.
Now I get to buy ANOTHER new sensor and I probably have a few shards floating around in my diff now. $55 mistake right there not to mention the time it took to solder on the sensor, wait for the silicone to dry etc.
OP, sucks to hear that. For the next one, you might consider using a set of calipers or depth gauge and measure the distance to the reluctor ring so you can set your clearance more accurately.
I may be off on my thinking, but trying to help. I'm learning as well...
