KYB adjustable shocks
Thanks for posting bmr2. You guys should offer a rod/rubber bushing combo like that. I set up a set like that for myself probably 15yrs ago. I've always been concerned about nvh stuff.
Fwi.....i even use that bushing on my mwc tq arm.
http://bmrsuspension.com/index.cfm?p...&productid=274
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
About the only way to get rid of the harshness of the rod end is to replace it with these. You only need to do one end of your lca. I like doin the body side best.
http://www.ridetech.com/store/rod-en...ng-insert.html
Now on to help you rectify it. Easy fix......look up mcmaster carr. You should be able to fish around on their site and find a spacers to work. Or cut your own. You would need 4 3/8" spacers.
I think you'll be fine once you turn down your spacers a bit. And likely be a easier way than i did it.
