KYB adjustable shocks
I see you're in Davison. You ever run at Lapeer by chance?
Double check and make sure you have everything tight also.
Did you bleed the shock before installing?
You're feeling what rod ends do. They make a car harsh.
If a shock is laying down or upside down the oil can drain out of the chamber it's supposed to be in and make the shock ineffective. They usually bleed themselves out but if it was your first ride it may/could feel like they aren't doin much.
About the only way to get rid of the harshness of the rod end is to replace it with these. You only need to do one end of your lca. I like doin the body side best.
http://www.ridetech.com/store/rod-en...ng-insert.html
And report back with your results......you can thank me then
They should be the same. I've changed out 2 different brands to the ridetech bushings and they have been the same. Double check yours but they are probably the same too.
Out of curiosity, who sold you on those rod ends? That's pretty hardcore S for a daily driver.
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
