Rear sway bar / anti roll - which one?
I have a 2000 SS A4. Right now the car has an unknown red lowering spring in it, as well as the factory bilstiens. It's a stock motor bolt on car. Fast 78 / fast 78 TB, long tubes, SLP LM1 exhaust, 3600 stall, 3.90's, and 315/30/18 Mickey Thompson drag radials. i installed bmr recloation brackets on the rear end, and that helped tremendously in getting the car consistently hooking up well. Right now it's doing 1.66 60' every time. Running high 7.70's in the 1/8, and 12.10 in the 1/4 @ 111. Now all I'm doing with the car is a low hp ET bracket racer, driving to the track, and running sportsman class 7.50 1/8 mile class. So it's not a rocket ship, and doesn't need to be. But on the 18's it's right on the edge of hooking or not. Running 16psi in the tires. Our track prep here in Portland is slightly less than desirable.
Now I'm ready to order a handful of pieces for the rear end of the car. I'm going with the hooker true dual setup for exhaust. I plan on the Midwest tunnel mount torque arm, Midwest poly / poly adjustable arms, Midwest poly / poly adjustable panhard, and some sort of a rear seat bar upgrade. The car is a 100k mile 2000 SS, so it's already got a few rattles, and I know it's going to make some noise, and loose some ride quality with all of these pieces, and that doesn't bother me too much, but I want to get the correct rear bar / anti roll for what I'm doing.
What I'm looking at is the Midwest chassis anti roll, the bmr anti roll, the umi anti roll, or just the standard upgrade bmr rear sway bar. Money isn't the issue, and ride isn't life or death as the car only drives back and fourth to the track, maybe 10-15 miles, a couple times a month.
Looking for the best bar I can get for what im doing.
LS1Tech Premium Sponsor
My recommendation will depend on how far you plan on going with the car in the future. If you plan on pushing it and going into the single digit range, then I would go ahead with our XSB001/XSB002 xtreme anti-roll bar. Out of the ones listed, ours is the most street friendly and has no concentration points that will break like a standard lever arm style bar. It also offers less noise and vibration transference. Our bar is also 100% bolt in.
If you plan on keeping it more simple, and don't expect to run faster than the 11-10 second range, I would stick with our standard upgrade swaybar SB003
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Im running the Midwest Chassis also. I do not like the bent bar stock style because they are heavy. I've spent considerable time and money lightening my car and do not desire to put something heavier then necessary on it. After careful consideration the TRZ and midwest bar were the two that got my attention. Midwest made me a good deal so I went with them.
Give us a call if you already haven't and we can set you up nicely.
