Lowering and ground clearance
I realized I need lca relocation brackets, then I realized that the wheels weren't centered in the wheel well, so I had to get adj lca's. Then after I did mods I need an adj torque arm, and after I installed it, I realized that the torque arm was hitting the bottom of the driveshaft arch on the bottom of the car (the tubing on the aftermarket ones are beefier and hit when you'd hit big dips or potholes going over 20ish). That's when I realized that the rear end wasn't centered left to right and I measured it... only to find out I needed an adj panhard rod. But now everything is exactly where it should be and it feels a lot better handling wise.
I never knew that lowering a car could cause so much trouble lol. Not everyone has these problems, but a lot do it seems. So hopefully you already have the stuff already or don't need it. With all my stock parts, everything worked fine except for the torque arm flexing, but nothing rubbed. But every time I walked to my car, all I could see is the rear wheels not being centered in the wheel well and I couldn't keep it that way
Definitely was a landslide of the wife not being happy when I say sweetie, I promise this is the last thing I'll need for the suspension. Then more bmr stuff shows up on the porch lol.
My torque arm isn't giving any issues, so hopefully it stays that way. In your opinion what suspension component made the biggest difference to you?
I had a 00 Firehawk with the old style BMR (1" drop) springs and stock manifolds and y-pipe. I'd scrape a little on speed bumps but wasn't a big deal like it is with long tubes.
I didn't know Moog makes rear isolators, but that's good to know if case I end up needing some. I'm running my stock ones and sits perfect for me. When I put the Koni shocks on it may be too low or too high.
I saw where the Koni was on back order, not sure if it's the yellow or orange but I know where orange ones are and for a great price, $319 shipped
It's the Moog 18-1901 isolator I believe. Eric at BMR said this should give the desired 3/4' drop
