Lowering and ground clearance
#102
Makes me think of my car. It looks to sit a little high in the front compared to the rear. I even installed the heater hose mod on my cars rear at first but went back to the OEM insulators to help level the car off. I might drop the spring to the lower perch on my front shocks(Koni SA's) when I add my C6Z wheels. Speaking of which how do you like the Cooper tires your running up front? I'm considering them for my Z06 wheels.
I like the Coppers for the price. They seem to handle and wear very well. I believe I paid about $140 a tire, so I'm very happy for that price
#103
I really thought the car was gonna ride a bit rougher but it doesn't. Combine that with the fact that it's much more solid overall, and handles leaps and bounds better, it's really a awesome upgrade for the money
#104
Thanks bud! Once I get the front/rear balanced out I'll be very happy
#105
Haha yes I can be a tightwad as well, but I I'm extremely impressed what these Konis do for the price. I'll keep you all posted on the ride height issue as well
#107
Yeah I honestly think you're right. It may drop a little possibly but not enough to match the rear I'm afraid. I just wish I knew why the front didn't drop any over stock.
#111
Im gonna call Eric at BMR here on my lunch break, and I agree on the fact that it probably won't all the sudden settle another 3/4". I just don't see how
#112
I'm considering doing the heater hose mod for the rear, but I want to raise it up only a 1/4" or so....no more. I already have the Moog isolator for the rear but just want that little extra 1/4" or so lift. Now I know that it can traditionally make up to 1/2" to 3/4" difference, but obviously I want less than that. Anyone know how to achieve this?
#113
#115
Get a 1/4 inch ring made to fit around the spring perches on your axle if you're wanting to raise it a 1/4 inch. I recommend something that will resist corrosion but also holdup to a coil spring bearing down on it like Stainless Steel. Aluminum would likely work fine, but is softer and more prone to damage, and IDK if the end of the coil sitting on it would start to cut into it when adding on the miles or not.
#116
#118
Well what I'm trying to do is get a very slight rake while still not dropping the entire amount due to my low hanging exhaust. The Moog isolator is slightly thicker than the stock one, but I'm not sure how it's gonna look when I pull the spacers out of the front. So I wanna have the heater hose just in case...this gives me more of an option to play with the ride height a little, and to hopefully get the desired result
#119
I hate to say it, but may be some trial and error to get it how you want it. Ever figure out anything on why it didn't lower the front?
BTW, something that just dawned on me that I completely forgot about. I put 1/4" worth of washers for spacers on mine and it actually lifted it up more than a 1/4", I'd guess 3/8"-1/2". So when you remove the spacers it may be too low. If so just use some washers and get it sitting just right.
#120
