ABS inop light and parking brake light
1998 camaro. I just bought 15x10 and 15x3.75 racestars. Had to grind the rear calipers and even the little metal tabs, took me a couple tries but i dont have any more grinding noise. However, at any random time, the ABS INOP and the parking brake light both will illuminate. Turn the car off, then start it back up and the lights are off. Drive down the road and they'll randomly illuminate again.
Not sure where to even start with this. Any ideas?
Are you running smaller diameter tires up front (or way bigger rear)? If you have ABS but the tires are smaller and the revolutions are a lot different, maybe the ABS thinks there is a brake issue. I've had those lights come on at a road course after a few hot laps. I think the ABS got confused because of super hard (and hot) braking.
I had the same issue about a year ago, but I was running 17's all around. Turns out I needed an ABS module. It comes off the abs pump with 4 hex type screws on the driver side. I dont have the part number but get you a new AC delco one if all your wheel speed sensors are good and you have matching diameter wheels and tires.
Just a side note, when those lights come on the car is very dangerous. If you hit the brakes hard and lock them up, it'll likely throw you in a spin (ask me how I know). So please be careful when you hit the brakes because it is dangerous.
