Suspension help plz
Car currently has 130k miles. Car has lived its whole life in Arizona, outside in the blistering heat. For that reason alone, im sure bushings are shot. Rear end is nice and solid as i have tubular rear control arms, bilstein shocks, and panhard bar. Car is a 1le so I'm assuming i have larger sway bars as well. I have noticed, however getting used to, a very sloppy front end. Seems like when I'm on the brakes hard, after a "race", front end seems mushy/ floaty! Its kind of dangerous even though I'm getting very good at controlling it. What all do you think might be contributing to this? Shocks are good, and tires are new. Do you think a bushing kit would resolve the issue?
With the car being a 1le, i cannot find a bushing kit that will fit unless I'm mistaken. What is the most cost effective way of making my front end more solid
The moog bushing kit will fit a 1LE:
http://www.stranoparts.com/partdetai...D=18&ModelID=7
Get under the car and check to see that the front swaybar endlinks are still intact and not broken or cracked.
