Watts link set up question
I've installed a Fays2 watts link and on initial set-up I had the bars parallel to the ground and the propeller top bolt between the 12-1 position. However, I've since moved the propeller down two holes, which leaves the propeller vertical and during suspension motion, especially under braking, the top propeller bolt will move to the 11-12 position. Is this ok, or should I extend my bars or move my brackets inward to get more propeller angle?
I just installed mine and have only driven it on the street. I've definitely noticed a difference. The rear seems more stable and consistent. You can also make finer handling adjustments than you can with just an adjustable sway bar. The true test will be at my next autocross next month. I can dial it in better there and I expect a better result.
I'd say the difference is noticeable, but probably not worth the money for just street use. I expect it too be worth it though for autocross.
LS1TECH Sponsor
Here's the thing... when you did that initial setup, the propeller needed to be in the middle hole when you leveled the arms. From there you can move up and down without any goofing with the arms again. But if you did the leveling with the RC all the way up, at some point as you move down you will run into an issue, moreso nearer the bottom.
__________________
LS1TECH Sponsor
Anyway, I'm not sure what the worry is, sounds like there isn't a problem at this point, and was simply telling you that when the arms are leveled at a high setting you can get to a bind at a low setting without readjusting the arms. But if you set stuff up in the middle to start you need never touch the arm angle based on a RC change.
__________________
Why not? I do it all the time. The clamps pivot, you can level the arms at any position. And frankly the instructions sometimes make things more complicated than necessary.
