control arm & bushing difference for SS model ?
Old Sep 1, 2016 | 08:40 PM
1 FMF's Avatar
Default control arm & bushing difference for SS model ?
I'm looking at rockauto and for FRONT UPPER control arms they list a set by Ultra-Power with "SS model" noted, but for 2 others by dorman and mevotech they just say front left upper or front right upper.
does anyone know if there is a difference, if so then what's the significance?
Attached Thumbnails control arm & bushing difference for SS model ?-802_ultrapower-mevotech_cms501136_2.jpg   control arm & bushing difference for SS model ?-cms501136_ang.jpg
Old Sep 2, 2016 | 12:25 AM
99SSJarhead's Avatar
I've never seen another aftermarket provider list the control arms as being SS specific but then this brand seems to be the sub basement of bargain parts so who knows. Probably easier to just source a stock one someone pulled off in the parts section after they switched to something like UMI.
Old Sep 2, 2016 | 08:33 AM
Darth Cypher's Avatar
What is wrong with your stock upper arms? Those were easy to replace bushings, clean, and paint up.
Old Sep 4, 2016 | 12:53 PM
leadfoot4's Avatar
I agree.
Too much questionable "inexpensive" stuff hitting the market, IMHO.....
Old Sep 4, 2016 | 02:49 PM
blackandgold's Avatar
No there is not a difference. But you won't get a lot of love for the mevotech stuff on here. Just get the moog bushings and ball joints and swap them in.
Old Sep 5, 2016 | 06:07 PM
1 FMF's Avatar
car is 14 yrs old i already replaced sagging rear bilstein springs, considering replacing front springs this winter, and get new tires. if i'm doing front springs and shocks i'm contemplating all the other high wear stuff and a whole new control arm with bushings and ball joint installed is atractive. i was not impressed with rockauto pricing for just bushings, seemed like it was 80% the price of a new control arm.
Old Sep 5, 2016 | 06:39 PM
That's because the moog stuff is awesome, I don't think I've ever heard someone recommend the mevotech parts.
Old Sep 5, 2016 | 07:32 PM
Never used this Mevotech stuff. But I replaced my bushings on my upper and lower arms as well as ball joints using Moog stuff. I could not be happier. Honestly, I would not take the chance. Stock arms are pretty good, especially the lower A-Arms. Seriously, I would just replace the bushings. It's cake on the upper A-Arms. Just need to rent the tool from your local auto parts store.
Granted, to replace the upper ball joints on the upper arms, I needed to grind it off with the Dremel but that was the most difficult part of it. And it was not that difficult at all honestly.
Old Sep 5, 2016 | 09:44 PM
1 FMF's Avatar
i am finding it difficult where to locate oem (i.e. rubber not poly) control arm bushings
is it moog K6689 for front upper and moog K6490 for front lower ?
Old Sep 5, 2016 | 10:07 PM
In this case moog is going to be as good if not better than OEM. I'm running moog in my uppers which are the only stock control arm left on the car. Part numbers:
Moog K6462 Upper Ball Joints x 2
Moog K6145T Lower Ball Joints x 2
Moog K6689 Front Upper Control Arm Bushings x 2
Moog K6490 Front Lower Control Arm Bushings x 2
Moog ES3238RL Tie Rod Ends x 2
