do i need front strut bearing plate insulator and mount assembly?
gonna be doing front suspension,
can someone give me a heads up on
$5 each, moog K6573 strut bearing plate insulator, do i need it?
~$50 each for strut mount, moog K6516/K6517 for left/right. do i need it?
and this says bearing not included, what is the bearing and do i need that?
thinking of doing umi viking coil overs, would not be doing the one with the rod bearing I prefer the stock mount for NVH.
i see on rockauto there's also "coil spring insulator" and "coil spring seat".
would i need either of these?
thanks.
thanks.
LS1Tech Premium Sponsor
thanks.
thanks.
I always recommend doing the small inner insulator plates (K6573). They are cheap insurance and usually the more likely to be bad. I have seen low mileage cars have them worn our or covered in rust from trapped moisture on the shock stud.
As for the whole mount (K6516/K6517), they are hit and miss. Usually they are ok to re-use, but I would still inspect yours for cracks or chunking
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
![](https://ls1tech.com/forums/signaturepics/sigpic136487_1.gif)
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
